I had already decided I was going to put wingtip tanks on it before someone mentioned it, frees up all the hardpoints for ordnance
I'm going to use some Zuni RP pods but all I can find in my stash at the moment is two of them. As I need these pods on other projects I'm going to make a mould of them and cast up a few.
Same with the other RP launchers you see there, it's those 'bazooka' styled ones with six launch tubes.
I'll go with just the two Mk.82 bombs with the fuse extenders and I'm thinking maybe two or four napalm bombs too (if I can find where I put them).
Under each outer wing there will be six pylons (off a Skyraider as that kit will be used for an AEW project) and the gun pod is an SUU-23. Only it won't be like that once I've finished with it.
The engine cowling comes from an Airfix Fairey Firefly Mk.IV which previously I had just cobbled together for the other project it will be used on (RAF F-82's but that's another story). I found that I had to modify it slightly so it would mate-up to the F-82 fuselage joint properly, I've had add a sliver of styrene strip to the glue joint, tapering from .5mm at the rear to nothing at the front. I also swiped a couple of exhaust stub fairings from the new tool Airfix Shackleton MR.2 kit, as in the backstory that's where the engines came from. I had to add a disk of styrene to the front because the Frog (spawn) Shackleton contra-props don't have enough spinner at the rear of the rear spinner, and also some styrene added to the rear of the cowling just to lengthen it a bit. I'll make some casting of this too, I've got a couple other projects I'm thinking of using them on.
So that's the plan so far -------
