Author Topic: F-86 Sabre and FJ Fury  (Read 19145 times)
ElectrikBlue
  • Guest
Re: F-86 Sabre and FJ Fury
« Reply #15 on: January 02, 2009, 03:46:57 pm »
For delta design with T-tail see :
http://www.airwar.ru/enc/xplane/nord1405.html;D
EB
« Last Edit: January 02, 2009, 03:49:07 pm by ElectrikBlue »
Offline Mossie
  • Twiglet doctor
  • What-IF SIG
  • Don't laugh at his mule
« Reply #16 on: January 02, 2009, 03:50:58 pm »
Ah, forgot about that one, thanks EB!  Looks very similar to Gregs profile bash, in plan view at least.
ElectrikBlue
  • Guest
« Reply #17 on: January 02, 2009, 04:04:20 pm »
There's another french plane from the mid-50's similar to the Delta 100 see :
http://www.aviastar.org/air/france/sud-est_durandal.php
EB
Offline sotoolslinger
  • hopes to get everything hung today
  • I am now fairly happy with my lower bits
« Reply #18 on: January 02, 2009, 04:52:51 pm »
KJ if you check out my thread on the Delta 100 I blended the wing roots with tank halfs so it does actually pinch right about the middle of the wing. I actually thought about adding bulges towards the rear (conformal tanks :blink:) but I'm not doing it on my model. :rolleyes: ;D
Offline apophenia
  • Posseses Photoshop-Fu of extraordinary magnitude
  • Kitbasher
« Reply #19 on: January 05, 2009, 03:46:04 pm »
Hmm, a delta Sabre and mentions of T-tails ...
In 1958, Canadair proposed a twin JT-12 strike aircraft -- the CL-76 -- using Sabre bits. That would give you something to do with those now-spare F-86 wings. Not sure what this beastie would've looked like but Canadair's Sabre-based bizjet was to have a T-tail.
Offline GTX
  • Beyond The Sprues Guy
  • What-IF SIG
  • "Princess"
    • www.beyondthesprues.com/Forum
« Reply #20 on: August 27, 2010, 02:22:56 pm »
Does anyone know if there is a conversion kit available to do a TF-86 in 1/48?
I have a hankering to try to do the CA-28 ‘Sabre Dingo’ in Plastic:
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #21 on: August 27, 2010, 04:38:51 pm »
Didn't Falcon do one in their 'Triple Conversion' series?
Offline kitnut617
« Reply #22 on: August 27, 2010, 05:37:32 pm »
Not in 1/48 scale, Kit.  I've got a couple of them in the 1/72 in the stash though.  The PAK-20 book doesn't list one from any outfit either, but that doesn't mean there might not be one.
Offline dragon
« Reply #23 on: August 27, 2010, 07:31:50 pm »
Whiffing Markings and Paint schemes for an F-86 is a tough job.  As it is, just about every non-Warsaw Pact Air Force seems to have operated the plane in some version or another from its entry in US service until 1996 (when Bolivia retired its ex-Venezuelan Air Force F-86Fs).  You might have to go anachronistic or something else clever.
Good Luck.
Offline rickshaw
« Reply #24 on: August 27, 2010, 08:57:09 pm »
Does anybody have a closeup picture of the FJ-3's wing fold?  I've been looking for one but been unable to find one.
Offline Logan Hartke
  • Rivet-counting whiffer
« Reply #25 on: August 27, 2010, 09:41:02 pm »
Offline rickshaw
« Reply #26 on: August 27, 2010, 11:15:00 pm »
http://www.primeportal.net/hangar/luc_colin3/fj-3_fury_135867/
Like these?
Logan
Thanks, they'll do nicely.  I assume that the piece of timber isn't normal equipment though?  ;)
Offline Chris707
  • Makes own decals
  • Took *both* the red and blue pills
    • http://www.dataviewbooks.com
« Reply #27 on: August 28, 2010, 06:12:06 pm »
I may have mentioned it before, but in the '60s there was a plan for a war emergency fighter based on stored F-86 airframes, with wing-mounted J85s and the fuselage given over to fuel. There was a similar proposal for the F-84F.
Aviation Resources
« Last Edit: July 11, 2011, 12:55:52 pm by Chris707 »
Offline MAD
« Reply #28 on: August 28, 2010, 10:54:00 pm »
Would love to see the end product Greg :cheers:
M.A.D
Offline rickshaw
« Reply #29 on: August 29, 2010, 06:56:45 pm »
Mmm, 1960s - "Dr. Strangelove", "Failsafe", Cuban Missile Crisis, exactly what sort of war were they contemplating?  Or was this intended for the Mad Max airforce post-apocalypse?  Seems to have been a bit of a disconnect there between planning and reality - not that isn't all that unusual...   ;D
