Author Topic: Dornier Do-17, 215, 217, 317, 417...  (Read 7289 times)
Offline GTX
  • Beyond The Sprues Guy
  • What-IF SIG
  • "Princess"
    • www.beyondthesprues.com/Forum
« on: April 12, 2009, 02:30:28 pm »
Hi folks - my rough interpretation of what a 4-engined stretched Do-217 might look like:
« Last Edit: April 12, 2009, 02:46:09 pm by GTX »
Offline Daryl J.
  • This is the Age of Imaginarius
Re: Dornier Do-17, 215, 217, 317, 417...
« Reply #1 on: April 12, 2009, 02:41:22 pm »
That looks good, Greg. :thumbsup:
Daryl J.
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #2 on: April 12, 2009, 05:13:02 pm »
Nice one, that'll be the Do-434 then?  -_-
Any aircraft can be improved by fitting longer wings
Offline PR19_Kit
  • What-IF SIG
« Reply #3 on: April 14, 2009, 02:07:02 am »
Oooh yes! 'Das Neue Ural Bomber' cries out to be done in plastic.
Do I have any Do-17 kits? No. Are any still in production? Probably not. Looks like eBay then.  >:(
Offline McGreig
  • aka The Incredible Shrinking Man
  • What-IF SIG
« Reply #4 on: April 14, 2009, 06:19:34 am »
The Airfix Do-17 was re-issued relatively recently (Hannants and my local Modelzone 10.99) and ICM do two Do-215s.
RS do a whole range of Do-17s, including the radial engined versions, but at over twice the price of the Airfix kit  :o an RS based Ural-Bomber could get expensive - - -
Offline PR19_Kit
  • What-IF SIG
« Reply #5 on: April 16, 2009, 09:09:55 am »
I may only need one Airfix kit. While digging around in The Loft I found an un-touched Monogram Do-17Z!
It's handy that the wings of any of the Monogram/Airfix/Frog Do-17s all fit any of the other kits, the spar cut-out is almost identical on all three.
Now I'll need a smaller early Do-17 type nose, I had one before and made a -17P out of it.
Offline Doc Yo
    • PreCognitive Dissonance
« Reply #6 on: April 16, 2009, 09:38:02 am »
 Neat concepts, but given what Dornier had already done with the Do 26 flying boat, and would do with the
 Do 335, I wonder if a 4-engined Do 217 wouldn't have had pusher/puller pairs, instead of four on the
 leading edge....You might have to tweak the landing gear to get the pusher props to clear...
Offline PR19_Kit
  • What-IF SIG
« Reply #7 on: April 16, 2009, 09:44:56 am »
...or do what they did with the Do-26, put a hinge in the nacelles and lift them up for take-off and landing?
Offline joncarrfarrelly
  • Bertie Bassett
  • What-IF SIG
  • Turn that Gila-copter down!
« Reply #8 on: April 16, 2009, 10:29:38 pm »
... and there is the tiniest Do 17 of all ...
the Goppingen Go 9
http://www.luft46.com/prototyp/go9.html
So how about buried engines and a counter-rotating pusher prop on a Do 17?
Jon
"Evil our grandsires were, our fathers worse;
And we, till now unmatched in ill,
Must leave successors more corrupted still."
Horace, 65BC - 8BC. Marsh translation.
Offline tomo pauk
  • Kitbasher
« Reply #9 on: May 05, 2011, 07:20:33 am »
(sorry to necro the old thread :) )
Ultimate Do-17, in push-pull configuration. Tandem seating for crew of 2, second engine just aft the wing. The U/C retracting would've needed some thinkering.
Perhaps an affordable anti-Mosquito?
Offline The Wooksta!
  • Resident Soup Dragon
  • What-IF SIG
  • Would you risk it for a chocolate biscuit?
« Reply #10 on: May 05, 2011, 07:59:44 am »
Except your base drawing for the 4 engined 217 is actually a stretched 215 - which is just a Do 17Z with DB601s for the export market.  The Do 217, whilst superficially similar, is an altogether different airframe.
"It's basically a cure... for not being an axe-wielding homicidal maniac... the potential market's enormous!"
"I am not a learning disability!"
The Plan - a Blog
www.whatifmodelers.com/index.php/topic,34762.0.html
Offline GTX
  • What-IF SIG
  • "Princess"
« Reply #11 on: May 05, 2011, 11:51:46 am »
Offline sequoiaranger
  • Gone but not Forgotten
  • Old Fart with too much time on his hands!
Fritz-X Dropper
« Reply #12 on: November 15, 2012, 06:57:47 pm »
I found a discussion at the "72nd Scale Aircraft" site:
http://z15.invisionfree.com/72nd_Aircraft/index.php?showtopic=2507&st=30&#last
on the Do-217M, extended-wing, reformed tail version that carried the heavy "Fritz-X" guided anti-ship bomb (the one that sank the Italian Battleship Roma).
Made me remember I have the "Guano Aeroplane and Zeppelin Works" aftermarket conversion kit and had planned to someday do a RW one from the Italeri Do-217K kit. And I have the Condor Fritz-X as well as another resin one.
Might actually semi-whif-it, making it Italian in desert camo, as if using it against British Fleet battleships in Alexandria (or Malta). Or against possible French immobilized ships in Toulon when Torch landed and the Axis were afraid that French Fleet units might actively return to the Allied side. *MIGHT* make it jet-powered like a He-343.
Offline dumaniac
« Reply #13 on: November 15, 2012, 11:21:55 pm »
can you make a 4 engined He111 diagram - I imagine an extended fuselage for a larger bomb bay
I have a couple of 72 scale kits to go that way
cheers
Bernie
He-211
« Reply #14 on: November 15, 2012, 11:39:10 pm »
dumiac: >can you make a 4 engined He111 diagram - I imagine an extended fuselage for a larger bomb bay<
Like ?:
http://www.whatifmodelers.com/index.php?action=gallery;sa=view;id=4100
One of these days I am going to "Phoenix" my own creation with a Lindberg He-111 fuselage (1/64 approx) to enlarge/lengthen it.
But what does this have to do with Dorniers (subject thread)???
