Author Topic: The flying road gritter  (Read 645 times)
Offline McColm
« on: February 11, 2018, 10:36:43 am »
 I haven't come across any business that uses aircraft to grit the roads when ice or snow is forecasted.
Weight and distribution are probably the key factors, plus low level flying in built up areas. I know that the military has a set limit of 150 feet and a special licence is needed to fly lower such as the Buccaneer not too sure if this applies to civilian or commercial aircraft.
 In the whiffing world bombers or cargo aircraft. Something slow and steady avoiding cities and large towns. Motorways and A roads would be temporary closed to avoid any damage to vehicles and reopened when the aircraft had passed overhead.
Offline Weaver
  • What-IF SIG
Re: The flying road gritter
« Reply #1 on: February 11, 2018, 08:30:44 pm »
Would have thought a crop duster would be highly appropriate - you could get an Air Tractor or something of that ilk and paint it up in Highways Dept colours... ;D
Neophyte: Is Eris true?
Neo: Even false things?
Neo: How can that be?
Principia Discordia
Twitter: @hws5mp
Offline Weaver
  • What-IF SIG
« Reply #2 on: February 11, 2018, 08:45:33 pm »
A helicopter is the other option:
You couldn't use spray bars of course: you'd probably have to have a wedge/pyramid-shaped hopper with a rotary 'grit flinger' on the bottom of it. Since you only need one crew and payload weight will be a big issue, the ideal things would be a converted gunship (hopper each side) or a skycrane type (hopper as a slung load). A KMAX could do either.
Principia Discordia
Twitter: @hws5mp
Offline rickshaw
« Reply #3 on: February 11, 2018, 10:52:41 pm »
I think an airship would be the best vehicle for this...   :thumbsup:
Offline McColm
« Reply #4 on: February 11, 2018, 10:58:33 pm »
Thanks for the ideas, keep them coming :banghead:
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #5 on: February 11, 2018, 11:36:53 pm »
A Belphegor, but you'd get complaints about the noise level.  ;D
Offline zenrat
  • What Would Deadpool Do?
« Reply #6 on: February 12, 2018, 01:17:45 am »
I can picture a Hercules flying down the M1 at just above stalling speed while gangs of unhappy squaddies shovel grit out the back like locomotive firemen in reverse.
"...the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Offline Weaver
  • What-IF SIG
« Reply #7 on: February 12, 2018, 03:48:51 am »
Of course the problem with a helicopter is it's limited grit capacity. You don't want to keep landing to refill, so that raises the prospect of air-to-air grit replenishing. You can't pump grit under pressure and gravity is by far the most effective moved of it, so your helo would have to have a very long (to clear the rotor), very wide diameter, upwards-angled replenishing chute with a conical, open-topped funnel at it's end. The 'tanker' (a C-130 seems favorite) would have a relatively simple delivery pipe, although keeping it aligned with the funnel might require flying-boom-style steering fins and an operator.
Principia Discordia
Twitter: @hws5mp
Offline Weaver
  • What-IF SIG
« Reply #8 on: February 12, 2018, 03:56:40 am »
It needs to be painted yellow, have an orange flashing light on top and the word 'SPREADING' printed on the inside of the flaps and the underside of the wings...
Dapol do a railways workmen set in 1/76th, although they might have trouble keeping their pipes lit on the open ramp of a C-130.
Principia Discordia
Twitter: @hws5mp
Offline McColm
« Reply #9 on: February 12, 2018, 04:17:17 am »
Got an Airfix AC-130H in the stash and a flying boom. Might paint it in Top Gear colours, and ditch the flame thrower :banghead:
Offline Weaver
  • What-IF SIG
« Reply #10 on: February 12, 2018, 04:32:56 am »
Crop duster kits:
Principia Discordia
Twitter: @hws5mp
