Author Topic: Seadude's surprisingly sensationalist........somethings?  (Read 3187 times)
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
Re: Seadude's surprisingly sensationalist........somethings?
« Reply #30 on: November 01, 2017, 04:27:27 am »
Did you gloss varnish the airframe before decaling?
It looks like the dreaded 'silvering' there, and usually caused by decaling directly over matt paint. AFAIK there's no way out of that short of prising the decals off and applying another set after glossing.
Since I started printing my own decals I've always scanned the decal sheet of any model I'm working with before using any of the items, then there's always some chance of printing off spares if you need them.
Any aircraft can be improved by fitting longer wings
Offline rickshaw
« Reply #31 on: November 01, 2017, 05:10:51 am »
I find a coat of future usually works out most problems...
Offline seadude
  • Think "outside the box"!
« Reply #32 on: November 01, 2017, 11:00:42 am »
No. Can't really do that as the temperature here where I live is in the 30's or 40's and getting colder and Fall is here. Anything I spray means having to open a window or door for ventilation so I don't choke on the fumes and that really isn't an option right now.
Yeah, I am heavily contemplating removing the walkway decals. My only option is if anybody asks why they aren't there is to say the walkway stripes detract from the "stealthiness" of the aircraft. Or maybe I can say this bird is a prototype that didn't recieve further markings yet, or that it's a further advanced "Block 40" aircraft sans extra markings to make it more non-visually stealthy. Seriously, I get why the USAF put the walkways on there. They want the maintenance crew to only walk in certain areas on the airframe. But IMO, I think those walkways kinda detracts from the stealthiness of the aircraft and makes it more visible to an enemy.
I don't have the luxury or resources to buy another kit just to get the decal sheet out of it or to print my own decals. And the printer that I do have is already broken.
Online DogfighterZen
  • Bmx, music and whif junkie
« Reply #33 on: November 01, 2017, 11:12:28 am »
Yup, i agree, should've gloss coated the whole thing before decals. Also, did you use any decal softener solution? That might help to make them conform to the surface of the model a bit better, even with no gloss coat but only if the paintwork is smooth enough.
You don't have to spray a gloss coat on, you can always apply it with a normal brush, right? Acrylic floor polish is a good option for that, it's self leveling and dries up clear and shiny.
Offline PR19_Kit
  • What-IF SIG
« Reply #34 on: November 01, 2017, 11:22:56 am »
Absolutely! I always brush on Klear coats, Future in the US IIRC, and it levels up superbly. You just need to be careful not to apply it too generously as it's prone to runs if you do.
Offline seadude
« Reply #35 on: November 01, 2017, 11:33:49 am »
I just did some checking in the kit instructions as well as research online. The kit instructions and decals are for the B-2 as it appeared during it's unveiling in November 1988. However, the kit instructions have one major thing wrong.........the B-2 during it's unveiling never had the walkways on it's wings.  :o  From what I remember, Aviation Week & Space Technology magazine managed to snap a pic of the B-2 from above during it's unveiling. That pic definately shows no walkways on the wings of the B-2. So.........problem solved!  ;D No need to put the walkways on.
The other problem: How do I take the walkways off that are currently on my model?
Offline PR19_Kit
  • What-IF SIG
« Reply #36 on: November 01, 2017, 01:05:11 pm »
As they aren't attached too well, that's what the 'silvering' means, you may find they'll peel off with the aid of a scalpel blade under one edge. Soaking with water as a second stage is worth considering if the first attempt doesn't work.
Offline seadude
« Reply #37 on: November 01, 2017, 01:42:28 pm »
They've only been on the model for about 2-3 days. Water? Doesn't using decal settling solution also help "lift" off decals too if need be?
Offline PR19_Kit
  • What-IF SIG
« Reply #38 on: November 01, 2017, 04:40:48 pm »
Yes, that'd help too, but I'm always at a loss to decide if the blue bottle or the red one is the correct one to use.
« Reply #39 on: November 01, 2017, 06:54:46 pm »
I'd use water if i were you, don't forget that the setting solution is to make the decal stick in place before a solvent is applied.
Water wont damage the paintwork unless you really scrape the surface. Like Kit said, try using the tip of the blade to lift it, after it's wet. But be patient and careful, it'll pay off.
The blue is microset, the one that helps with holding the decal in place, the red is microsol, again, like the name implies, it's the solvent solution that makes the decals conform to detail. Normally, the method is to apply the setting solution first, and the solvent afterwards, works for me.
Offline Old Wombat
« Reply #40 on: November 01, 2017, 07:00:08 pm »
Warm water works best, unless you've already clear coated over it.
Offline PR19_Kit
  • What-IF SIG
« Reply #41 on: November 02, 2017, 01:39:56 am »
Magic, thanks. I'm going to save that text as a file so I don't forget.  :thumbsup: ;D
« Reply #42 on: November 02, 2017, 02:56:43 am »
 ;D   :thumbsup:
Offline seadude
« Reply #43 on: November 02, 2017, 10:54:08 am »
I'm calling this one done for now.........unless somebody else has an idea or suggestion on anything to add? Finally managed to get the walkway decals off that were on the left side of the aircraft. ;)
Offline seadude
« Reply #44 on: November 02, 2017, 10:55:19 am »
