Author Topic: What do you want from Freightdog? suggestions needed....  (Read 19583 times)
Offline McColm
Re: What do you want from Freightdog? suggestions needed....
« Reply #255 on: August 24, 2017, 11:25:17 am »
Replacement set for the guns carried on a AC-130 Gunship.
QuickBoost do the resin guns for the AC-47, apart from scratch building there's no alternative.
Offline McColm
« Reply #256 on: August 25, 2017, 10:26:05 am »
There are several resin kits for the F-16 conformal fuel tanks.
The Typhoon and the advanced Super Hornet are due to include conformal fuel tanks in the latest update.
Is it possible to get the two ends cast and sand the resin body into shape?
Offline McColm
« Reply #257 on: August 26, 2017, 10:12:14 am »
Would it be possible for you to do a conversion of the Dassault Breguet Br1150 Atlantic 1 ATL1 to the Atlantique 2 ATL2.
L'Arsenal do a ATL 2 set but the price is more than the Revell or Mach2 kit.
They also do the Exocet missile rack.
I'm not too sure if there's a resin Exocet missile set in 1/72 scale.
Offline Rolead
  • Out of the Whiffing Closet
« Reply #258 on: October 19, 2017, 08:47:51 am »
Hi Colin,
Can we have a new nose for the new Airfix Phantom in the A&AE scheme please.
Robert
Offline Freightdog862
  • Moderator
    • http://www.freightdogmodels.co.uk
« Reply #259 on: October 19, 2017, 02:12:41 pm »
Hi Colin,
Robert
Bloody good idea Robert, I take a look at that.
Colin
Offline McColm
« Reply #260 on: October 19, 2017, 02:56:27 pm »
Any chance of a civvie nose for the 1/72 Consolidated Catalina?
  • Moderator
« Reply #261 on: October 19, 2017, 03:01:51 pm »
Maybe, why not.....
Offline McColm
« Reply #262 on: October 19, 2017, 03:10:53 pm »
Maybe, why not.....
I usually get shot down in flames if I suggest something on this page.
Thanks
  • Moderator
« Reply #263 on: October 20, 2017, 04:16:15 am »
Maybe, why not.....
Thanks
Don't worry, all suggestions are considered, quietly. I have a friend who works with the Catalina Society and has a massive library, will ask him. Problem might be that like many civil modifications, the can vary from one to another. I have a Broplan set that I think has faired over nose? Anyway, I will look into it as I'd like to do some civil stuff.
Colin
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #264 on: October 20, 2017, 07:00:37 am »
The ex-Danish Air Force Catalina at Cosford has a turret-less nose that's been carried over to many civvie Cats as well.
Any aircraft can be improved by fitting longer wings
Offline McColm
« Reply #265 on: October 20, 2017, 09:51:29 am »
Maybe, why not.....
Thanks
Colin
Thanks Colin
The Airfix kit is the PBY-5A amphibious variant, whilst Revell do the MkII A which has beaching gear. I have both in the stash and they don't line up. The Airfix is slightly longer.
RVHP do the PBY-6 conversion set in resin.
I'm not too sure about the other manufacturers what marks their kits are based on.
« Last Edit: October 20, 2017, 10:18:25 am by McColm »
  • Moderator
« Reply #266 on: October 20, 2017, 12:34:01 pm »
The Academy kit is probably the best starting point, although even it is getting quite long in the tooth now. Think I have an Airfix one in the loft but it doesn't really compare with Academy versions.
Colin
Offline McColm
« Reply #267 on: October 20, 2017, 03:27:39 pm »
I maybe wrong but didn't Freightdog used to do a 1/72 4 blade propeller that could be used on a Avro Lincoln?
I haven't seen this for quite some time, as most publications make the mistake and say that the Avro Shackleton has eight contra-rotating propellers. It would make an interesting whiff.
Offline McColm
« Reply #268 on: February 09, 2018, 11:06:54 am »
Would it be possible for you to cast the fore and aft nose cones of the BAe Nimrod AEW.3 in 1/144 scale as this would fit neatly in the range of 1/144 AWACS conversion sets available?
The  Cammett/MasterCast set in 1/72 doesn't seem to be restocked. There was an inferior set available on eBay but that's not available either.
Offline kitnut617
« Reply #269 on: February 09, 2018, 05:31:37 pm »
I have a civvie nose for one of the Academy Catalinas. Made by Scott McTavish who runs an outfit called Invader Hobbies. He had a shop in Calgary but has since closed it up but I think he's now only on Facebook or something like that.
